Topology Suggestions Wanted
Posted by: HighHopes on
hi all, i would like some suggestions on which flyback design reference would best match my DC/DC SMPS  needs.
Vin: 60Vdc to 180Vdc
Vout: 12V, 5% regulation is fine
Power: ~20W, constant load
Isolation required(1500V)
Open Frame
preferred no heatsink (less parts)
Board space not an issue
Profile not an issue
Efficiency >60%
EMI not a concern
UVLO required
Sensitive mostly to availability of parts for one-off build (suitable transformer available from digikey?)
Low part count preferred (hand soldering)
looks like design idea 152 would be my best option?
what if i wanted >80% efficiency, what would the suggestion be then?
Submitted by VCastrellon on 03/14/2014
I would recomend a TOPswitch controller in a flyback topology.
how do you chose between topswitch or tinyswitch-4, looks like they could both work..
Submitted by VCastrellon on 03/17/2014
TinySwitch may work too.  The reason I decided for TOPswitch is that you need 20 Watts at 60Vdc(minimum Input voltage)
So you will need a device with high current limit to work when Vin is minimum.  Also you do not want heatsink.  This is why I decided about TopwSwitch.   But you can try a Tiny too.
