TOP249YN makes so much noise
Posted by: nhuan
Hi everyone !
I have used PI Expert software to design 2 power supplies 12V - 5A use TOP249YN.
I measured their output voltages with the output current 500mA.
When using the oscilloscope to measure output voltage, the measurements need to be done as indicated in section 11.5 of the below link. I think after using this method you would not see what you are looking now.
http://www.powerint.com/sites/default/files/PDFFiles/der105.pdf
Thank you very much !
you are welcome
And the other is this
I use my receiver with the 1st supply, it 's good, but the 2nd is too bad.
So, what cause the different between them?
