RDR-313 gerber files do not have drill hole diameter info
The RDR-313 zipped gerger files do contain the through hole drill locations but not the through hole drill diameter. Does anyone have the hole diameter information? I would think the hole diameter is needed to fab the PCB, yes?
There is a file in the zip folder with name : RD-313-12V_30W_REVB-1-2.drl This file has the drill sizes
The rd313gerber.zip file linked on the Parametric Search web page does not contain a file called RD-313-12V_30W_REVB-1-2.drl
The is the link to the zip file: http://www.powerint.com/sites/default/files/docs/rd313gerber.zip
It does contain:
BOARD_OUTLINE.art
BOTTOM.art
FAB.art
MASK_BOT.art
PASTE_BOT.art
place_txt.txt
RD-313-12V_30W_REVB.brd
SILK_BOT.art
SILK_TOP.art
SLOT_OUTLINES.art
I am still working with the PCB design team to fix this issue. I will provide you a solution later today
I am attaching a zip file with the complete documentation
I am sorry the information posted in the web is not completed as it should be. The web master will fix this issue soon
Let me know if you are able to open the file I am attaching. If not, then I may need to send it to your email
Got it, I was able to DL and open the zip file, there are 13 files in there and I can see the RD-313-12V_30W_REVB-1-2.drl file in there as well.
Let me try to find the information
I will reply as soon as I get it
