PIXLs Secondary Winding located on the primary side
Posted by: wes@egauge.net
Is there any way to have the PIXLs software move a secondary winding to the primary side?
I need a 5V rail on the High Voltage side of the flyback converter as well as the normal 12V output on the secondary side.
I assume I can just edit the transformer construction file afterwards but I wanted to check if there is a way to do this.
I did above changes Kindly provide layout guideline for Secondary Winding located on the primary side
Layout guidelines are provided in PIExpert and not PIXls. Kidly create the same design in PIExpert to see layout recommendations.
You can change the pin allocation of the transformer and have the 5V rail terminate to the primary side.
Active Design -> Edit Design -> Winding Construction --> Pin Allocation
