PIXLs Designer Parameter description
It is not obvious what the meaning with all parameters in PIXLs Designer are. Is there a description anywhere?
I use it for LLC converter calculation.
Also: I thougt I should search the forum for it but I did not even find out how to search the forum (!) ...searching the forum should be easy.....am I stupid?
Hi.
We're actually working on trying to make the complicated spreadsheets a little more readable.
In the mean time I suggest you use the application note as a guideline when designing. You can find it here
Good Morning all
I am an industrial electronic engineer; I want to develop a low cost and isolated stabilized power source:
-Input AC Voltage Universal (85V-265V)-
-Out CC Voltage 5V DC
-Output Power 1W
-Output current 200Ma
I have already used your expert PI tools to design this feed based of integer circuit LNK623.
I need your recommendations to anticipate risks and optimization if possible?
Is there another equivalent of the transformer PC40EE13-Z?
You can find attached my concept and BOM.
Also, I search to make all components type SMD.
Best Regards
| 첨부 파일 | 파일 크기 |
| Isolated_Power_Source.JPG (40.19 KB) | 40.19 KB |
| BOM_Isolted_Power_Source_Based_LNK623.pdf (234.22 KB) | 234.22 KB |
Hi Walidayari,
Thank you for reaching out to us through this page. But if you may, please kindly raise this inquiry as a new request. We'll wait for your new ticket on this.
Thanks and Best Regards,
PI-Lupin the Third
Hi PI-Lupin,
Thank you for your reply
I create a new request "Design Low Power Design Isolated 5VDC/1W"
probably I do not need details om parameter meaning any more. The reason that there was no parameter explaination was that it was a warning on the parameter. When I modified the design and the warning dissappeared the explaination appeared......however a visible forum search function is still missing
