PI Xls designer software
Dear all;
I use PI Xls designer software. Transformer design button is not active for hyper series IC. How can I active it or How can I get transformer specifications?
best regards,
Dear all;
best regards,
Hi kenlin,
For the Hiper family, we don't have a transformer datasheet for PIXLs. The spreadsheet itself has the data you need in terms of wire, number of turns, etc. With that data you can go to the respective application note (http://ac-dc.power.com/products/hiper-family/) to get some guidelines. If you still have some questions please use the high power forum (https://ac-dc.power.com/forum/technical-forums/high-power-design/).
-PI-ODO
Hi Erdem.
For the hiper family we don't have a transformer datasheet for pixls at this point. The spreadsheet itself has the data you need in terms of wire, number of tunrs, etc. With that data you can go to the respective application note (http://ac-dc.power.com/products/hiper-family/) to get some guidelines. If you still have some questions please use the high power forum (https://ac-dc.power.com/forum/technical-forums/high-power-design/)
I hope this helps.
