Not getting power as designed
Posted by: subratsadhana on
Dear Sir,
I designed a smps using TYN 268 as circuit provided by PI expert.
The spesification are : Input voltage 150V to 280V AC and the output voltage is 12V,1A
The core used EE19.
The problem is that, I am not getting appropriate power. When I draw 500ma current, the output voltage false bellow 7 V. I can not findout the problem,Please help me.
I attached the circuit diagram provided by PI expert.
smps_0.pdf (53 KB)
SMPS 12V 1A.uds (258 KB)
Submitted by PI-Wesley on 06/09/2014
Hi.
Assuming you are using the transformer provided on your uds file (71 turns prim, 8 turns sec, 951uH), it should be able to deliver the power without issue, so we can discard transformer design as an issue. The schematic itself also seems to be ok.
Having said that do you have equipment to verify inductance? If yes you can check LP, and you can also verify whether the polarity of your transformer is correct. To do so, you can short circuit pins 2 and 5, and measure inductance between pins 1 and 6. If this value is bigger than Lp then polarity is ok.
You may also have layout issues. Have you followed the recommendations that can be found on the tab "Board Layout" in PIExpert?
You can also try to add some resistance in series with VR2 (something like 470Ohm), place BP as close as possible between the BP and Source pins, remove R1, remove L2 and connect your load directly to C6, remove C4, remove R3. This series of tests is just meant to help you a little bit with the troubleshooting by simplifying your circuit. You should probably test in between each step to see if you get any improvements.
Submitted by subratsadhana on 06/15/2014
Thanks for your support.
   You are right,  there was a problem in circuit. As your suggestion, I was try to troubleshooting in step by step, when I shorted the L2 (3.3µH) at output, the problem was shorted out and 1 Ampear current can be drawn  without much voltage drop. I measured the resistanceof the coil L2 is 7Ω , so there was a much  volltage drop causes while the lode current incresed.
Anather thing is that, I have  some quireis, please clear me :
1. When The load current incresed, there is a sound produced in transformer (which is thightly wound). How this can be reduced.
2. What is the "Fit Estimate" , in percentage, shown in the result after optimisation.
Submitted by PI-Wesley on 06/23/2014
1. Try to varnish the transofmrer or reduce the maximum flux density
2. The software will try to check if the wire will fit in the winding area of the transformer.
Submitted by subratsadhana on 06/24/2014
 Thanks Sir, Please tell...
What are the procedure or technic to reduce the maximum flux density.
by increasing the number of secondary turns, or increasing the size of the transformer. If your transformer is not varnished I would suggest that first.
I would also suggest look at an-14, an-16 and other application notes that can be found here: http://www.powerint.com/en/design-support/application-notes
