LNK306 Stackfet Reference Design
Posted by: WEKA on
is there any refernce design for applying the stackfet design on a LNK306 in buck converter operation?
Attached you will find a suggestion, based on other stackfet designs. What do you think?
Thanks!
Jonathan
Submitted by PI-Terry on 05/28/2014
Looks like you adjust the other stackfet reference for flyback power supply to the buck application, it is the same principal, so you could try.
You need a stackfet solution, because the input voltage range is very wide in your application? What is the intension to put the R122?
Submitted by WEKA on 06/01/2014
Hello Terry,
attached you will find a new schematic, which is tested and works fine.
I removed the SUF4007 and 5k6 because it made the output voltage unstable. I thought it might work as kind of bootstrap circuit, but its not necessary.
Furthermore I tested different resistor ladders and TVS diodes to get best heat dissipation.
R122 is for EMC reasons and kind of total fail protection.
Input voltage goes up to 700VDC, therefore I need the stackfet design.
Thanks!
Submitted by PI-Terry on 06/02/2014
Good job. Thanks for sharing the good news.
