DI-152, TinySwitch III, 18-265VAC, 3W
Posted by: maxjosel
I'm looking for a design with 18-265VAC input voltage range like design idea DI152 from Power integrations, but with a power of 7W.
DI-152 is a tinyswitchIII design and has only 3W!!
Does anybody know how to get 7W?
If it is not possible, does anybody know how to get it with an other PI chip?
Thanks a lot
José
Thank you very much but I'm new with PI expert and I don't know how to add new components
Could you help me, please?
Thanks a lot
You do not add the components in PI expert environment. You add the componets to your peototype aftre you created a design and you know it is working properly
OK, thanks a lot
I really apreciate you helps
josé
You need to use a Tiny switch device family
Create a design using PI expert and enter your VINMIN as low as the program would allow you to enter
Selec an oversize device. In other words select a device that can handle much more power than the power you need
Then add the extra circuits for the supply to run at very low VIN
Test your device. If you can get 10 % more of your desired power at VINMIN, then you are safe about the tolerances of the circuit.
You can download PI exper following the below link
http://www.powerint.com/en/pi-expert-download
