TOP223Y replacement
Posted by: garydeck
I have an existing design that utilizes a TOP223Y for an offline, 12W DC supply. I am planning to update the design and am wondering if there is a newer part that would be a drop-in replacement for the TOP223Y. Thanks
Is the TOP223Y EOL or should I expect any difficulty with being able to continue obtaining this part? We are presently using approximately 250 parts per year.
Gary -
I haven't heard anything about TOP223Y being EOL'd anytime soon but I'm also not involved with that stage of product planning. When a product is EOL'd, we notify customers as early as possible to give them an opportunity for an EOL purchase.
-The Traveler
There isn't going to be a 100% drop-in replacement but there are a few IC's that will be very close. With TOP223Y being an older product, I would recommend looking into updating the IC even if you don't make use of all the new features available on the newer IC.
TopSwitch-HX:
http://www.powerint.com/sites/default/files/product-docs/tophx_family_datasheet.pdf
This is the most up-to-date TopSwitch IC family availble in the Y package (TO-220).
From this product family, TOP254Y is going to be the closest match. It has a 1.3A current limit compared to TOP223Y's 1.0A current limit so you're need to use an external current limiting resister. To make this IC as drop-in compatible as possible, you can use the 3-terminal configuration of the IC found on Page 16 Figure 16 of the datasheet.
TopSwitch-GX
http://www.powerint.com/sites/default/files/product-docs/top242.250.pdf
From this product family, TOP244Y is going to be the closest match. It has a 1.3A current limit and will need the external current limiting resister. Three terminal configuration is covered in Figure 16 on page 15 of the datasheet.
TopSwitch-FX
http://www.powerint.com/sites/default/files/product-docs/top232-234.pdf
TOP233Y is the closest match from this product family. It has the same 1.3A current limit as the previous two options I list. Three terminal operation is covered in Figure 13 on page 12 of the datasheet.
I hope this is helpful. If you need anything else, please let me know.
-The Traveler
