Power Supply designing
Posted by: OZAN on
I designed a PSU. In my design, the outputs are   Vo =36 V and Io=1,4 amps. I used PI Expert and i choose TOP266, and i select openframe instead of adapter selection. However, after I ordered the transformer, i recognize my mistake:
P = 36 x 1,4 =  50,4 W
For TOP266,
max.power of adapter selection is : 40 W
max.power of open frame selection is : 86 W
For TOP267,
max.power of adapter selection is : 55 W
max.power of open frame selection is : 103 W
So can i use TOP267 intead of TOP266 in the same desing according to TOP266?
Submitted by VCastrellon on 09/23/2013
how do you want to use your design?   in open frame or adapter?
Submitted by OZAN on 09/26/2013
We want to use adapter form.
Submitted by VCastrellon on 09/27/2013
I understand now
You can not just replace the TOP266 for a TOP267  But it may be possible to have a simple solution.  Depends on the actual design.
Do you have a resistor connected between the  X pin of the TOP266 and PRIMARYRETURN or you are connecting directly the X pin to PRIMARYRETURN?
I suggest you post your schematic and your PI expert files for the transformer design , then we can run some calculations and try the simplest solution that works for you.
