Minimum supply voltage of switchers
Posted by: acscontsys
For a converter 20...253V ac/dc with output 24V/2W we use the TOP234G, that works very well since more than 10 years.
This switch starts working from 16 V dc.
Now I have to design a similar design with output 24V/11,5W.
For this output power the TOP234G is not suitable.
What switcher is able to work especially at the input voltages <=20V ac resp. dc and >=253V ac at such a higher output power?
Hi Terry,
the design is open frame.
Hi, I did a roughly calculation. I think TOP268VG/EG from Top JX may be a good starting point.
Thanks for contacting PI. You can use our lastest TOP switch which is TOP Switch JX.
Is the power supply open frame or close frame?
