LNK306G problem with microcontroller
Posted by: kitopsey on
Has anyone had problems with the input capacitor? I'm having trouble because if I change the input capacitor of the circuit 10uF/400V to 10nF/400V seems that it is more stable when using the microcontroller with a voltage regulator 12V down to 3v3.
The circuit in attached.
Submitted by PI - Traveler on 07/23/2013
I'm really not sure what you're asking.
-The Traveler
Submitted by kitopsey on 07/23/2013
well, I projected a non isolated ac/dc with lnk306G to interface with uC for dimmer ac light. But the circuit are unstable I dont know why. When I measured the input (Vin=12Vdc) regulator the voltage are OK, and Vo of regulator 3v3 are ok too, on the osciloscope the waves nothing out normal. But the AC lamp blinks, and when I tested the same circuit with external supply with same Vin=12Vdc of regulator the dimmer did not blink, I'm almost certain that problem is with LNK non-isolated power supply.
Can you send me a schematic and some waveform captures of what you're experiencing?  It's really difficult from your descrpition to get a sense of what problem you're having.
-The Traveler
Hi, I caught the wave for zero cross detecting following the schematic. The wave had noise, and this noise makes disturbance in uC to fire triac, I think. Because the lamp is oscillating. when I change power supply by external SMPS this problem not appear.
Submitted by PI - Traveler on 08/14/2013
It's not clear from your schematic or from the attached waveform what you're trying to do and what the problem is.
-The Traveler
