battery charger design of 14volt/ 1amp
sir,
i need design for 14volt/ 1ampere battery charger circuit using top switch hx type, with dual led indication showing charging and if fully charged.
can i get help as it is very urgent.
ashish
Can this ckt be used with solar panel as well?If yes how?
In what way would you intend to use it with a solar panel?
-The Traveler
Ckt shold have option to charge battery with Solar panel as well as A.C.Means ckt works as solar controller as well.
If your string of solar panels could provide enough voltage and current to keep the charging circuit up and running, then sure I guess you could do this. However, you would have no MPPT and the efficiency of your overall system would be non-optimal.
-The Traveler
I am also searching the similar design for my panel and I have a rm791 battery which I am going to use. I am looking for a duel led indication circuit.
You would need to use some additional secondary side circuitry for your LED indicators.
The Traveler
This design example may help
http://www.powerint.com/sites/default/files/PDFFiles/di12.pdf
