TopSwitch with non-isolated output, control input fed from output voltage
Posted by: mike4321 on
Hi ,the application is a battery charging circuit to charge an internal battery (12V, 2A). Therefore there is no insulation of the output voltage required. In order to simplify the design (and most important, reduce the cost), is it possible to eliminate the transformer's bias winding and feed the control pin from the output voltage ?
Is there any application available without the bias winding ?
Thank you, Klaus
Submitted by ssundar2020 on 10/08/2012
Yes, you can use the output voltage instead of bias voltage for feeding into the C pin and use a transistor circuit instead of opto-coupler.
rgds..
Submitted by bsprague86 on 01/14/2015
Do you have an example schematic of such a design?
Submitted by PI-KSAN on 02/04/2015
Thanks for posting your question into forum, We really apologize for delayed response.
The TopSwitch regulates the output voltages using the Control Pin Current. Please see the below link for Such design:
http://ac-dc.power.com/design-support/reference-designs/design-examples…
In this design , we were using DPA Switch. use that as an example to design for your specification.
PI-KSAN
