TOP 266EG Power supply
Posted by: Logesh Padmanabhan on
hI,
We made one power supply by using Top 266EG, its not take desiged power,ckt diagram made by power int sftware only.
No of outputs 15V,3A ; 5V , 1A; 15V,1A
I/p range 85-265AC
Logesh.P
Submitted by PI - Traveler on 09/26/2012
Logesh -
I don't understand your question.  Can you please explain in more detail what problems you're having?  Can you also attach your PI Expert design files?
-The Traveler
Submitted by Logesh Padmanabhan on 09/27/2012
HI,
By using power int software  we designed power supply for 15V,3A; 5V,1A  and 5v, 1A. its having 3 outputs...
v got the output voltage as we designed.but its not taking load. means voltage getting dip.
can u tell me what are the changes need to be done....or which part i need to concentrate.
otherwise send some application note for 15V,3A; 5V,1A  and 5v, 1A.(isolated) outputs.
pls do the needful
Submitted by PI - Traveler on 09/28/2012
This isn't enough information to help with your questions.
Can you please send me the following:
- the files from your PI Expert design
- A PDF of your PCB layout
- A PDF of your circuit schematic (if it is significantly different than shown in PI expert)
- Some better information about what conditions cuase the poor load regulation.
-The Traveler
