Stand alone power supply
Posted by: Brad Carey on
Hi, I've been requested to design a power supply for an industrial application to support:
Universal input 85-295 Vac
Output: 4.5 amps.
Short circuit protection
Overload protection.
Looking for support to determine which family of devices and if there is a reference design to get me going.
Submitted by PI-Tucker on 06/22/2012
What is the output voltage?
Is the output voltage really 295 VAC, or did you mean 265 VAC?
Submitted by Brad Carey on 06/22/2012
24vdc output and 4.5amps
24vdc @ 4.5amps
Submitted by Brad Carey on 06/25/2012
Thanks.  However. not sure if this is the right starting point.   Bcecause I missed providing some information, my general design requirements are the following.  Product to be used in 120/240 Split, 120/208 3-PH, and 277/480 3-PH.
1. Universal Input:  90-280 VAC
2. Output Voltage: 24 VDC
3. Output Current: 4A
4. Volumes are high, so low cost is key.
Submitted by PI-Tucker on 06/25/2012
Does it have to be the same design for all 3?
277 VAC max is not 280 VAC.... so how can 90-280 VAC be sufficient?
Does it need to have PFC?
Yes, it is the same design for all three.  It's my understanding that in 3-PH systems they will pull input power from just one leg.  I got the customer to provide a spec sheet for what they are currently using.   Apparently, the issue is one of availability and the spec's not being what they want.
PFC would be nice.
Submitted by PI-Tucker on 07/05/2012
For 280 VAC max and ~100W you can use the TOP-JX family:
http://www.powerint.com/en/products/topswitch-family/topswitch-jx
Browse our design examples page for ~100W flybacks (look for those which use TOPSwitch-HX and JX):
http://www.powerint.com/design-support/reference-designs/design-examples#general
"PFC would be nice" - either your spec requires it or doesn't.  Adding PFC when you don't need it will add cost.  If you do need it, PI has the HiperPFS product:
http://www.powerint.com/en/products/hiper-family/hiperpfs
Submitted by Brad Carey on 07/05/2012
I have selected a reference design starting point.   I would like to know if the design files for PI Expert are available for the RDK or I just need to enter the basic informaiton again?
Submitted by PI-Tucker on 07/06/2012
Sorry they are not, but you can recreate it by entering the values shown in the report.
