Problems with PI Expert Download
After submitting the form you should receive an email with the download link. Sometimes this can take a few minutes, so give the email a little time to show up. If you have, and you haven’t received it, then it could be being blocked by a spam filter or may have been automatically moved into a junk email folder. Please check these your end to ensure that’s not happening.
If you are still having problems, please Contact Us.
I have a 64 bit Windows 7 operating system,when i try to download the file it shows not a valid application. I tried installing both the packages 32 bit and 64 bit. It seems that the installer is corrupt.
Instaler is working.If u use Firefox just rename file with extension *.part ..... remove this extension and ad at least one letter in name to change it.....press enter and it will work.U will have working exe.
after several try not received any mail.
then i send mail to webservices@powerint.com, reply received but still no download link.
please help.
For users with problem related to "download completes, but installer does not run"
If your download completes (i.e: If the browser confirms "Download Complete"), then go to the download location and located the downloaded file. Ensure that the extension of the downloaded file is .exe; if not, change the extesion and run the downloaded file again.
can't seem to download and no response as yet from webservices. would someone mind sending me the download link?
thx!
nevermind i found it :)
didnt recieve the email for download link for the software.
Kindly share the link....
Did you check your spam folder?
When try to download allways on the page shown
The form has become outdated. Copy any unsaved work in the form below and then reload this page.
I have downloaded PI Expert tool for 64bit os , while installation it is showing error message "Error reading setup initilization file"
Please suggest
The file could be corrupted during the download process. Can you please try it again?
I am manufacturing 24V, 2.5A SMPS using lnk6666e, in some of SMPS I am facing issue where when I am power up the circuit, it doesn't give any output. But when I am switching off the input supply, it gives 24V output for 1 sec.
Circuit diagram attached herewith.
Please provide solution.
| Circuit diagram (1.46 MB) | 1.46 MB |
Thank you for your interest in PI products.
If may I suggest, can you please create a new post for your inquiry since the thread was for problems with PI Expert download? We'll wait for your new post.
Best regards,
PI-Lupin the Third
I have repeatedly failed to download the newest version of PIExpert and have never received a reply to my emails to webservices.
