PFS712 load vs. power supply
Posted by: agrego on
Dear all,
we would like to use PFS721 where the input voltage goes from 180V to 230V AC. In
all this range we would like to maintain constant load of 450W. The question is, could we
maintain this load? In data sheet there is only maximal load at 90 VAC, but there is no
detailed description, about load vs. input voltage.
regards
Submitted by PI-NANO on 07/26/2012
PFS712 is a universal input device, which can deliver upto 225W at 90V AC input.
For PFS device lowest input voltage is the worst case condition, if the PFS device could deliver the certain amount of power at lowest input voltage then it can deliver the same amount of power at highest input voltage as well.
Since your operating input voltage range is 180V AC to 230V AC, I would recommend you to use PFS726EG device which can deliver the required ouput power (450W) over the given input voltage range.
PI-NANO
Submitted by agrego on 07/26/2012
thank you for answer. But in our case somethimes the lowest voltage can be 150V AC, therefore we chose the
PFS71x family to operate. What can happen if more power is desired like PFS71x is specified? Would be just
more power dissipations or some other thermal current protection will activate?
When I am looking data sheets, there is no difference mentioned between devices, except, that Rdson of integrated
MOSFET is different, what lead to more power dissipation!
thanks and best regards
Submitted by PI-NANO on 07/30/2012
If you use a low power rated device, PFS device will enter into power limit mode and might not be able to deliver the required 400W. If you are in final stage of your design, I would suggest you to replace the PFS part with PFS716 part (provided all other components are rated for 400W in the design already).
PI-NANO
Submitted by agrego on 07/30/2012
so If I understand correctly we can use PFS operating near PEAK output power, but above lower supply
limit. So PFS716 operating with 400W output power and power supply ranging 150 - 230V AC can operate
stable and will maintanin stable output voltage and harmonic distorsion within limits like for FPS714 measured in
RDR-236 application note.
When you mentioned, that device can enter into power limit mode, the output will be fully disconnected, or output
voltage will be lower then calculated 380V?
You also mentioned FPS716 design for 400W, but I can only find design of FPS714 (347W output.)! Could you send me a link to this design please!
Thanks an best regards,
Submitted by PI-NANO on 08/02/2012
Yes, PFS716 can deliver 400W ouput power and it can maintain regulation..
As you keep on increasing the load, the output voltage will go down once the device enters into power limit mode.
At this point of time we have reference design for PFS714. But unfortunately we don't have a reference design for PFS716. But the design procedure is same as PFS714.
You can use PIXls designer to design with PFS716. PIXls designer is a free downloadable software available Power Integration's website. You can find the PIXls designer at following location.
PI-NANO
thank you for a tip. I downloaded SW and checked our design. On design schematics I have noticed, that
there is Csn1 capacitor which should be used for universal design > 350W. This capacitor is in paralell with
PFC fast diode!
Do you ahev any guideline for value/type of this capacitor, because I can notfind it in design.
regards,
Toni
Submitted by PI-NANO on 08/06/2012
Csn1 is used to snub the voltage spike on PFC MOSFET. You may not be required to use this capacitor If the loop area is small. But I recommend you to have a place holder for this capacitor. If you observe a voltage spike the drain, then I suggest you start with a 22pf / 1KV, NPO capacitor and optimize it further after checking the waveform on bench.
PI-NANO
