lnk404 does not regulate the current
Hello
I use lnk404 to power 6 LEDs with current 350mA. When you turn on 5 LEDs, the current drops to 250mA. Current control is not what is the problem?
I used the design of the transformer with application http://www.powerint.com/sites/default/files/PDFFiles/rdr193.pdf. I do not understand the issue of measuring the voltage when connected load. Maybe you were referring to current dimension? I measured the current tektronix DMM4050.
In the same document. http://www.powerint.com/sites/default/files/PDFFiles/rdr193.pdf . Did you do the fine tuning as indicated in page 18? If you have not done you should do it. Also please read section 4.2 " The V Pin current and........."
Hope this information will be helpful to you
Did you used PI expert for your transformer deign? can you please post your transformer deign? What is the measured output voltage when you connect the load?
