leakage inductance
Posted by: seo on
Hello, I was wondering how to measure up leakage inductance. (for example RDR292 - measurements carried out on the frequency 100 kHz). For me it is possible to measure up only at frequencies 100 Hz and 1 kHz. Which devices does PI use for such measurements? Thank you.
Submitted by LinuxGuru on 09/23/2012
IMHO if you measure it at 10KHz (for example with BK Precision 87x for example) it will be enough.
I've measured leakage inductance of wide band toroids at 1 KHz and 10 KHz, numbers were very very close.
Submitted by PI-Neela on 09/25/2012
LCR meter or impedance analyzer can do the measurement. You short your tansformer secondary and measure the inductance through primary. To be specific, in RDK292, measure between Pins 2-5, with FL1, FL2, FL3, FL4 shorted.
Submitted by seo on 09/26/2012
Thanks, I understood. I measured operating frequency with an oscilloscope and determined leakage inductance by the formula.
