Flyback DC-DC converter design
Posted by: henry301128 on
I have a problem for using DPA425GN to construct a flyback DC-DC converter. I have a working flyback module which use DPA425GN. Its input voltage is 24-60VDC, output voltage is 5V/2A. But I need a 20V/0.75A output module. So, I changed transformer turn ratio and resistor divider to be able to output 20V voltage. After I get revised module, I use 24V input voltage to test it, it works. Output is 20V. But when I change input to 50V, it fails to oscillate. Output voltage is around 8V.
Can anybody help me with possible cause for this issue?
Henry
Submitted by VCastrellon on 03/19/2012
You need to check your transformer design using PI expert PIXLs.
Download the program from PI website and create a new file in PIXLS for the DPA425.
Once you have the file, Enter your input variables.
Then enter your number of secondary turns and change the reflected voltage to match your actual primary number of turns.
Adjust VB to match your bias winding number of turns
Adjust KI to match your actual external current limit
Adjust KRP/KDP to match your transformer primary inductance.
This process is called reverse engineering and needs to be done to check the basic transformer's parameters. Any mismatch of your actual transformer will be showed in the program.
If you can not find the possible mismatch issue, then you may post your schematic, your transformer design and a waveform of the DRAIN current and DRAIN voltage when the supply is not properly working
Submitted by henry301128 on 03/22/2012
In reply to by gyh
Thanks a lot for the comments.
I have checked the transformer design per your instruction and didn't see issue there.
Schematic and a few waveforms are attached here for further comments.
Transformer design docs are attached as well. More transformer data are as below.
Primary - 18T pins 1-2
2L #1350 tape
Sec - 24T pins 9-7
2L #1350 tape
Aux 14T pins 4-5
2L #1350 tape
The core area for the EP13 core is 0.2cm^2.
Henry
Submitted by VCastrellon on 03/23/2012
I saw your documents. I have not checked your transformer design yet. Can I ask you to disconnect R159 and R20 and connect the L pin of the controller to primary return?
Then run the test again and tell me if the supply works fine at higher input voltage.
PI-Worf
Hi, Worf,
I removed R159 and R200, and connect U59 pin2(L) to pin8(S). The failure is still there.
I noticed drain current already exceeds protection limit(3.5A). So I short R250, the current limit changes to 5A. Then I captured transformer pin1 V/I waveform as attached. The power supply still doesn't work. It looks reflected output voltage is not big enough.
I still need your help on this issue.
Henry
Submitted by henry301128 on 03/27/2012
Hi, Worf,
Are you still work on this issue?
Henry
Submitted by VCastrellon on 03/27/2012
Hi Henry,
About two days ago, I sent you a private message to your email. I need you reply for me to send you a transformer design.
Submitted by henry301128 on 03/28/2012
Hi, Victor,
I have responded email to you. Could you please send over spreadsheet file?
Henry
