DPA422PN UV AND OV CALCULATION PROBLEM
Posted by: 168 on
dear pi engineer:
the picture attached is from the datasheet of the DPA422PN.
can u explain these two equations for me? what does IUV stands for? what is the value of VL?
Thank u in advance...
Submitted by ssundar2020 on 02/15/2012
I_UV stands for line under-voltage threshold current. This is the minimum Line sense current that needs to flow into L pin to start switching. It is a technique to sense the line voltage. Typically I_UV is 50uA and I_OV is 135uA as shown in Typical Electrical specification table. V_L is line pin voltage for respective Line under (2.35V) and over (2.5V)threshold currents. Please refer to Specification table in the data-sheet.
So to explain the 2 equations:
VUV = IUV x RLS + VL (IL = IUV) (determines Min input voltage to turn ON the switcher)
VOV = IOV x RLS + VL (IL = IOV) (determines Max input voltage to turn OFF the switcher)
So you can use this equation to set your Minimum and Max Input (Line) voltage.
rgds..
Submitted by 168 on 02/18/2012
thanks for ur reply.according to ur opinion, i should use IUV=50uA and VL=2.35v to calculate the VUV. and i should use IUV=135uA and VL=2.5v to calculate the VOV. do i understand u correctly?
Submitted by ssundar2020 on 02/21/2012
Yes, your are right.
rgds
