TOP414 scheme calculation
Posted by: aj26
Hello! How can I calculate board parameters for a TOP414 design using Piexpert (or PIXls Designer)
I need a scheme with following requirements:
24 VDC input, three outputs:
5VDC output (0.5A current)
2.5 VDC output (0.2 A current)
3VDC output (0.5A current)
Can I use the programm or I have to calculate everything manually?
(if there is another solution instead of top414 please let me know) Thank you!
The matter is TOP414 provide an opportunity to use 24VDC input while other products not. Can you advice a chip for dc-dc conversion with requirements listed above? thanks a lot!
Use our PI Expert software to design using the DPASwitch for Lower voltage DC-DC designs.
-Wesley
These product is no longer supported in the PI Expert Suite of tools.
I am sorry about that. May I suggest you look into our latest TOPSwitch device, TOPSwitch-JX? It has many improvements and added features.
Hope this helps.
-Wesley
