TOP250R-TL
Posted by: SANDRA PARICH on
TOP250R-TL has a small amount of lead in it. My suppliers list this part as Non-rohs. I have a customer that requires this part in the manufacture of their printed circuit board assembly and they want a Rohs-compliant assembly. Is the amount of lead in this part a small enough amount that the part can qualify as Non-rohs or is the part Rohs compliant by exemption, or is the part strictly Non-rohs? If it is Non-rohs, do you have an equivalent or alternate that is Rohs-compliant?
Submitted by PI-Wesley on 12/13/2011
Hi.
This part f the forum is usually for PIExpert questions only.
The TOP250R is indeed a non-rohs part. You can use the TOPSwitch-JX family (specifically the K package is also surface mount). The TOP-JX has the same switching frequency, tighter tolerance, lower no-load and standby consumption. If you require a heatsink then you will need to use the E package.
The TOP268K or 269K have very similar power capability to the TOP250R, but because I don't now the exact spec it's hard to say exactly what IC is best for you.
Submitted by LFilipe on 01/27/2016
Do you have a version of TOP250R-TL that is ROHS compliant?
I need the part to have the same package (TO-263-7C).
