Tny274 design Replacing VR1 and D5
Posted by: e2f on
Hi I have a design that calls for:
D5 = FR106 and VR1 = P6KE200A unidirectional
In my design I have replaced VR1 with a SM6T200CA bidirectional TVS instead. I was wondering whether this has a negative effect?
If not, would it then be feasible to remove D5 altogether and just use the bidirectional TVS instead?
Submitted by PI-Spock on 06/07/2011
What do you mean by bidirectional TVS? Can you draw a sketch and post?
If you change the polarity of the TVS you will short the transformer winding when the blocking diode conducts.
Submitted by natb1 on 06/16/2011
It looks like your proposed SM6T200CA would conduct during TinySwith-III "On Time", when Bulk Voltage (Volts across C1/C2)exceeded ~200VDC (assuming 85-265VAC IN).
This would be undesirable.
Submitted by PI-Spock on 06/16/2011
I am hesitant to say it will work. I dont know what the turn of characteristics of a bi directional TVS are like when it is working like a regular diode. In the forward direction how fast can it turn on? This turn on speed needs to be less than 500 ns.
I suggest you use a unidirectional TVS and a regular high voltage fast diode.
Submitted by e2f on 06/17/2011
Thanks for your replies. I have this circuit working with the SM6T200CA and the series diode (ES1J). Thanks for the explanation natb1.
