power supply for IGBS driver
Posted by: wxzhuhua on
Hi, all,
I am trying to build a power supply for an IGBS driver, which need to be as below:
1. 5V as input voltage(for the IGBS driver), which have input GND.
2. 18V and -5V as output voltage(for the IGBS driver), which have output GND.
So here is my question, is it possible to build such a power supply with a single PI chip?
BTW: i can't input -5V when trying to use PIExpert, why?
Zhu
Submitted by wxzhuhua on 02/22/2011
No any recommendation?
Any help appreciated.
Submitted by PI-Sarek on 02/22/2011
We do not make any parts that can operate from voltages below 16V. You may be able to find parts from other manufacturers that can better suit your application.
PI-Sarek
The input is AC, 85~265V.
the 5V i mentioned is a voltage that IGBT driver need, which is called input voltage since it's power supply for the input part of driver.
I need to add a 3.3V now, so i need 4 voltages with 2 GNDs:
input side of driver: 3.3V, 5V, they have GND1
output side of driver: 18V, -5V, they have GND2
And the total power is small, 2~3W is enough, the 2 sides all need to have good isolation from AC and each other, i think off-line flyback is a good chioce, is it right? please tell me your recommendations on chip selection and any other considerations.
the problems i'm facing is:
1. PIExpert does not support the input of negative voltage.
2. PIXls only have 3 position for output voltages.
Please help, Thanks.
Zhu
