PI Expert 8 input voltage error, 30.00V interpreted as 3000.00.
Posted by: iggy on
Hello.
Just downloaded PI Expert 8 and found out that I can't use it. When I enter 30.00V for Vout, it interprets the value as 3000V. I am using Vista 64bit.
I am unable to circumvent the problem right now. Help?
EDIT: exact error says
Selection: Input parameter 'VO1' is equal to 3000.00.
Solution: Input is greater than the maximum limit of 100.00.
Submitted by Tim Starr on 03/31/2011
Just type "30" in. PI Expert may not be interpreting the placement of your decimal correctly along with the trailing zeros you have entered.
-Wesley
Submitted by iggy on 04/01/2011
Tried it, no dice. The SW always assumes decimal places. I am thinking decimal separator.
Submitted by Tim Starr on 04/04/2011
Interesting, let me talk to our software guys about this and see if we can reproduce it on a Vista 64 setup. I may request additional information from you. Would you be willing to give me that so we may better help you and improve our software?
Submitted by iggy on 04/04/2011
Of course, I'd be glad to help.
Submitted by eregun on 11/30/2011
im start to use at work and home piexpert. and only output voltages page is have problem. im write only 5 and program add to extra 00 and i give this message. i havent problem at work.
