LNK30X ability to withstand secondary voltage with no input
Posted by: Raybased on
Dear All,
We are using an LNK306 (might change to 304 or 305) which is used to power an energy measurement device (high volume).
Output voltage is 12V which feeds a relay and linear regulators (3.3V) which powers the micro and other circuitry.
During production the device is calibrated and programmed via a "bed of nails".
It would be very convenient if the circuit could be powered directly by 12V via the calibration equipment, instead of powering it from 230VAC.
Is the LNK30X able to handle 12V at the output without being fed the 230VAC at the input?
No destruction? No overheating? No reduced reliability?
Best Regards
/Jan @ Raybased
Submitted by PI-Sarek on 07/26/2011
If the data sheet recommended values of currents through the device pins and the voltage on the device pins are not excedeed, the device should be safe.
We will need to review your complete circuit and understand how your bed of nails fixture will be connected and the resulting current flow in the circuit before we can specifically say whether it will be aceptable.
Having said that, I would imagine that if your fixture applies 12V to not only the output of the power supply but also the input, that may not be a problem. However I would suggest you send us a copy of your schematic so that we can confirm.
PI-Sarek
Submitted by Raybased on 07/26/2011
Thanks for your quick reply,
While I'm at home (it is 2AM in Sweden) I will have to wait for tomorrow to send schematic.
Is there an email address I can use. I don't want schematic to be out in the open on the forum.
/Jan
Submitted by Raybased on 08/21/2011
Our circuit is mailed to you
Submitted by Raybased on 09/26/2011
Any response?
Submitted by Raybased on 10/19/2011
I have been asked to provide more information, which I have done.
But still no reply!
Best regards
/Jan
Raybased AB
Submitted by PI-Sarek on 10/19/2011
When designing the test fixture, please ensure that none of the datasheet parameters are violated when voltages are applied to any of the pins during test. If this care is taken, it is OK to apply 12V at the output during test.
I hope this clarifies.
PI-Sarek
