DER-301 modification
HI,
I'm trying to build a LED candle driver base on DER-301 reference design, however i want to know if what changes do i have to make if i want to adjust the output to 40mA/100VDC or 20mA/200VDC. Basically im using a HV DC LED source with low forward current, 2 HV leds are inside the LED source and can be connected in either series or parallel. Series (20mA), parallel (40mA). thanks.
what should be the value of r3 and r5 if i want 20ma and 40ma?
what should be the value of C7 if i want a 200VDC output?
VR1 value should be as per the required Vf of the LED?
what about the values of the other components?
where can i find application note with the formulas?
i live in dubai, who is the responsible distributor in our region and how can i get the samples?
thanks.
1)Since the current sense resistor value of 80 mA is 4.5 ohms, the sense ressitor values for 40mA will be around 9 ohms and 18 ohms for 20 mA.
2)C7 can be 6.8 uF / 250V for 200 V output.
3)The voltage rating of VR1 for 200V output will around 220V.
4)There is no any other component value need to to be changed.
5)The only LinkSwitch-PL Application Note is the AN-50 up to this point.
6)Digi-Key and Farnell are the PI's world wide distributor.
You might need to change the following components in the DER-301,
1) R3 and R5 for lower output current
2) C7 for higher output voltage
3) VR1 for higher OVP (vout + 20 V)
4) Remove R7, C8, and R6 for non dimming application
