900 W PFC Stage Using HiperPFSTM
Posted by: harrison on
in the design report of 900 W PFC Stage Using HiperPFSTM
PFS729EG,the inductance of LPFC at full load is 237uH and 2370uH at no load.
Question No.1:
so is 237uH the calculated value at full load?
what is the percentage of ripple current?
Question No.2
while I don't see a problem with higher indctance at lower load, but this is 10:1 ratio of zero-inductance against full load inductance, is n't it too big?
I usually use 2:1.
are there any problems associated with higher inductance?
Thank you
Submitted by PI-Surak on 08/03/2011
The core used is 125u type Sendust so inductor will "swing" considerably. This is actually desirable because the converter will tend to be in continuous conduction mode over a wider load range as compared with a more linear inductor. Power factor is better when converter is operating substantially continuous over the AC input envelope.
Submitted by harrison on 08/08/2011
Thank you very much for your reply.
please have a look at the table on page 16, Inductor construction parameters, it says the core loss is only 2.07w.
I checked the specifications of the core and I got much higher core loss than it is in the table.Can you please doublr check if this 2.07w is correct?
thank you,
Submitted by harrison on 08/13/2011
Thank you very much for the reply.
while reading the whole note for this PFC, the last part is about winding the toroid;
for the second ayer winding(the same for third layer), why not winding the same direction as the first layer?
the way of this winding , the second layer is counter-clockwise while the third layer is clockwise, would they cancel each other?
why it has to be split into two halves to wind this inductor?
Thank you very much
