600v 10A
Posted by: harrison
I need higher current,regarding your Qspeed diodes,do you have anything at 600v 25A or higher?
which model you are talking about?
in both Q and H seris,the maxim is 12A,QH12TZ600
on second thought, I only need average curent to be 10A, so this 12A should do the job.
your X series has 20A, but Qrr is too high.
am I correct?
thank you
As long as the average forward current is below the rated value and make sure that the junction temperature is within specified limits, then your current rating is satified. I do not know your application, you will just need to find the device that meets all of your requirements for Qrr, Vf, Imax and breakdown voltage.
Z. Cochrane
THe haighest current rating for our 600 V diodes is 20 amps.
Z. Cochrane
