TOP247Y overtemperaturature shutdown problem in some parts of the Batch "J508 TOP247Y 32952A"
Posted by: pentaindustrial on
Good morning.
There´are some threads similar of mine, as below:
"Power supply shuts off from time to time" and "Linkswitch-XT LNK364 temperature problem with 2 of 100 chips from one production lot".
I have gotten a over-temperaturature-shutdown about 40 to 50degrees in some parts of the Batch "J508 TOP247Y 32952A". It is very interesting that if I change the part by a new one, the circuit works correctly.
I tested 20 power supplies in an oven at 70degrees. I did the following procedure:
**Heated the entire power supply in the oven at 70degrees for 5 to 10 minutes.
**Then I catch out it from the oven and fed the power supply with 120Vac(it was developed to work from 80 to 240Vac), but it simply do not work. The Top247Y simply do not try to start(I checked with the osciloscope). There is not a start pulse. Nothing.
**When the temperature decreases, the power supply startup and works fine.
Than I bought 10 new TOP247Y from the same batch and supplier, and replaced it in the power supplies that was not working. And them worked well, but 3 of them showed the same problem.
I think it is a problem in this lot. Why some of the parts have the overtemperature-shutdown problem and others not? A large quantity, about 30% has this problem.
I checked TOP247 datasheet. There was a mension about the maximum soldering temperature, time and distance from the terminals to the case. But I respected this concern when I welded that last 10 parts, but the problem repeated in some parts(3 defective parts of 10).
I think that whether the problem was the project(layout, values, etc...) the problem must not went away when I changed the parts.
Awaiting for your answer. thank you a lot.
Eduardo.
Submitted by VCastrellon on 10/29/2010
Eduardo:
What I think is happening is that the design is marginal. In other words, it is in the border of functionality and because the tolerance of the parts, some parts work fine but some parts do not.
The first thing we have to do is to is to review your design, Can you please post your schematic, transformer design documentation and pcb layout?
We start from here and then we decide what to do ok?
Thank you
Victor castrellon
Submitted by pentaindustrial on 10/29/2010
ok.
I´m going to send the design to you by email. Thanks.
Submitted by pentaindustrial on 11/24/2010
Dear Mr. Victor.
I would like to know whether you received my last e_mail(november/3/2010), with the graphs you asked me to take from.
Thank you a lot Mr. Victor.
Best regards. Sincerely
Eduardo
In Mon, 01 Nov 2010 16:09:07 -0200, Victor Castrellon Victor Castrellon wrote:
The next things I need from you please are:
To send me the waveforms of DRAIN Voltage and the DRAIN current with the conditions (VIN and Load) where you saw the problem. These waveforms may tell me if the is a problem.
Make the oscilloscope time to show about 2 to 4 switching cycles of the waveforms. Also take other pictures with the oscilloscope set at 1 or 2 mS/ Div.
Can you attaché a thermo-coupler to the TAB of the device and tell me the temperature of the device whit the conditions when the problem is observed?
I contacted PI official distributor in Brazil. Then, they send me some samples and ALL OF THEM WORKED VERY WELL, even in high temperature as 70degree.
So, I understand that the problem can be with some parts of the Lot I´ve mentioned.
Thanks for all assistance.
Sincerely
Eduardo
