TNY278GN-TL device FIT rates
Hello; Can you please provide the device FIT rate for the TNY278GN-TL?
- Confidence Level for FIT rate calc (eg, 60% CL or 90% CL)
- Operating Temperature for given FIT rate (please specify if the given temperature is ambient or junction)
- Activation Energy used for FIT rate calc
Thank you, very much appreciated.
Can you provide the MTBF for TNY278GN at 55°, 99% confidence?
Hi Glen,
For Power Integrations product reliability information, please contact our QA hotline at CIM@power.com. When doing so, please specify the product of interest and provide as much detailed information as you can.
-PI-ODO
The failure rate in the field is much more related to the incidence of voltage spikes let through the input filter ( if any). For any spike > 750V for > 20uS on the HVDC bus the likelihood of failure is very high ...
The failure rate for the TinySwitch-III and TinySwitch-PK product families is 1.0706 FITs (MTBF = 934,021,000 hours).
This failure rate was estimated by de-rating the high temperature reliability test data to an application use junction temperature of 55 deg C, using an activation energy of 0.7eV and was calculated with a 60% confidence level.
