Problems with input voltage compensation LNK603
Posted by: dense
I desinged a flyback circuit with LNK603 and have some problems with des variation of the input voltage. The device should work from 195V up to 264V AC. Output is 3V 200mA. The design is without Bias winding. The output characteristic is strongly dependend on the input voltage (picture). The difference is more than +-10%. Is there a possibility to influence that with an external circuit? Do you know where the reason could be.
Thanks a lot
Dense
Here is the circuit diagram!
Thanks in advance
Thanks in advance
Could you please post your schematic, transformer design and a picture of your pcb layout. I need this information to dig into the problem
Thnak you Pi-Worf
