install program
I download PI expert but cannot get it to run. It starts the HD is addressed, but nothing else happens. I used the previous version a while back but tried to upgrade to 7.01.can anyone gige me a few hints?
Bill
I have a similar problem but no older version installed
The install shield wizard starts an then disapears without having instaleld the software
I tried that but I still could not install. I found that I had the same problem with another program. I am going to clean out and format C: drive and start over.
Thanks for your reply.
Bill
You may try to create an installation log file by starting setup.exe with certain command line parameters:
setup.exe /v"/l*vx \"C:\place for logs\install.log\""
where "place for logs" folder must be created beforehand.
There will be a huge log file created there - try to analyze it, perhaps, you will have to find Error words.
AS a first step I would uninstall any previous versions of PI Expert you have installed.
Then download a complete install from http://www.powerint.com/en/pi-expert-download
and then see if that works. Let me know if it doesn't!
-Wesley
