design SMPS
Posted by: lotfipi on
I need to design SMPS with the following features using TNY255:
Input: 220VAC - 50Hz
Output: 12VDC - 5A
is it possible with TNY255? If yes, Please could you help me about this issue?
Submitted by PI-Tucker on 09/10/2010
This is way too much power for the TNYSwitch.
Pls. refer to the power table in the datasheet.
The recommended part family is the TOPSwitch-JX. Pls. go to the JX page.
Then download the PI-Expert Suite for design tools.
Submitted by lotfipi on 09/10/2010
many thanks for your support and help.
Submitted by chirag.prajapati on 09/16/2010
I Have one SMPS application in which the input volt variation is 90-600v A.C. & output is 24V 5A
Can u suggest me any part no of your product. so that i can use in my product.
Submitted by lotfipi on 09/18/2010
you could use TOPSwitch-HX or TOPSwitch-GX family devices in flyback topology.(refers to datasheet to select the best one)
you have to use PI expert, it's really so useful to design your board.
Submitted by chirag.prajapati on 09/19/2010
Can u give me reference design for(90-600v A.C. & output is 24V 5A) same?
Chirag Prajapati
Chirag Prajapati
Submitted by lotfipi on 09/20/2010
I have a model with input 90-300 vac and output 24v, 5A
it's attached.
