Can I generate extra CV output for LinkSwitch-PH
I would like to know if I could generate auxiliary CV 5V on top of the LED CC output using LinkSwitch-PH. Is there anyone out there that could provide me with the info. I am posting a new thread because nobody reply my previous thread for more than 1 week.
John
Thanks for your reply.
In fact, I would need 2 output.
1) 50VDC, 0.3A
2) 5VDC, 0.1A
The 50VDC will be used to power up LED. The extra 5VDC auxiliary output will be used to power up a microcontroller. This microcontroller will be used for other functions such as remote on/off and dimming.
In fact if possible, what I would like to achieve is a constant voltage output using LinkSwitch-PH. LinkSwitch-PH simple PFC design is attractive and I would like to know if I could generate CV using this switcher. From what I have read from the datasheet, it seems like it could only generate CC.
John
LinkSwitch-PH maintains CC while LED string voltage changes. For your 5V CV, maybe you can use a separate winding and linear regulator to get it.
Thanks for your suggestion.
I have 2 more questions
1) Refering to Page 9 of 42 of the document RDR194 - Reference Design Report for TRIAC Dimmable 14W LED Driver Using LinkSwitch-PH LNK406EG.pdf
"Resistor R1 provides a discharge path for C3 with a time constant much longer than that of the rectified AC to prevent the V pin current being modulated at the line frequency."
I would like to change C3 to Polyester Cap with lower capacitance e.g 0.22uF/400V and change R1 to 1MOhm. Is that fine? This will roughly come up with the same time constant.
2) Do you have any recommended standard heatsink for Linkswitch-PH?
John
Can you please provide more information, such what's the purpose of this 5V, what's the load current and is it at primary side or secondary side?
