Y-capacitor
In the very well-written "AN-40", page 7, the following paragraph seems not so clear to us: "Designs using a Y-capacitor require the EMI filter impedance to be placed on the appropriate side of the input. Therefore when Y capacitor is returned to the DC rail, the fusible resistor(s)/Filterfuse should be placed in the opposite side of the input". Any interpretation of this paragraph would be highly appreciated.
Hello theswissguy,
I agree with you, some of our older applications are with the Y capacitor connected on the opposite side. All our designs are tested for EMI compliance and we confirmed some EMI improvement if this capacitor is connected to the AC line without filter components. Most of our low power applications are not using Y capacitors anyway, and the newer schematics are with the change we are discussing here.
Cheers,
PI_Crusher
Hello theswissguy,
Sorry for this paragraph. All you have to do is replace “impedance” with “component”. You will read “Designs using a Y-capacitor require the EMI filter component to be placed on the appropriate side of the input.” Check attached picture.
Cheers,
PI_Crusher
