TOP262-HX support
Posted by: tjames
It doesn't look like the TOP259-TOP262 parts are supported in the PI-designer. Is it possible to add them??
I was referring to the parts library in PIExpert. I have the latest version 7.1.4.4. It seems like it would be easy to add them to the parts library if that were possible! (I haven't puttered with the PIXls yet.
TOP259 through TOP261 are included in PIExpert. PLease check to see if you have chosen the correct package (I suspect you have the P package selcted) IF you select the E package you should be able to access all the way upto TOP261.
The TOP259 - TOP262 are supported in PIXls designer. Are you sure you are running the latest version? The latest version is 7.1.4.4
