Power supply does not work if bias winding voltage reduce
Posted by: SD on
I have design 24V/5A supply using top258.
Power supply is working fine when the bias voltage of the transformer is 42V.
I have asked for the Xmer manufacturer to reduce the voltage by decreasing the no of turns.
But by doing this my supply does not work it oscillate.
Can anybody tell me what is happening in this regards and how can i tackle this problem
SD
Submitted by PI-Sarek on 04/17/2009
42V is unusually high voltage for the bias winding. This voltage is higher than the rated operating voltage of most optocouplers that are typically used for feedback.
Generally a 15V bias winding is most appropriate for most designs.
Please send us a copy of your schematic to help us understand why your design needs such a high voltage on the bias winding.
PI-Sarek
Submitted by SD on 04/17/2009
I have attached schematic of my supply for ur reference.
Actually we dont need 42V bias voltage but some how due to the transformer it goes to 42V. So i have replace 27V over voltage zener by 42V.
How can i drop the bias voltage?
I have discussed this problem with Xmer manufacturer so they made some changes in Xmer, reduce the bias winding turns.
But now my supply is not working with new Xmer. It oscillate ON-OFF.
It works fine with the older one.
Please suggest me some solution to this problem
Submitted by SD on 04/20/2009
