PIExpert obtains Vbias=70V for a Design with Universal Input, LNK363, E-Shield transformer, Feedback Bias Winding
Posted by: cabedikes on
I have designed a SMPS, using PIExpert, with following requirements :
- Universal Input
- 10V/250mA and 20V/40mA Outputs
- LinkSwitch Family
- E-Shield transformer
- Feedback by Bias Winding
Applying this values, PIExpert calculates Vbias=70.3V I have not any troubles on using this excessively (I think) high voltage on my design. But, why is so high Vbias? I'd like to understand the reason. Does the E-Shield construction of the transformer condition the number of turns of Feedback Bias Winding?
Thank you very much for your assistance!
Submitted by PI-Spock on 05/07/2009
LNK363 is LinkSwitch-XT family. PI Expert design for your spec returns about 27 V on the bias winidng if you use Bias winding feedback.
I guess I am a,little confusd about what exactly your problem is, as I cant reproduce it. Would you elaborate or send me a PM.
Submitted by cabedikes on 05/11/2009
What does PM mean?
I send you the PIExpert report, converted to .pdf file, of my design. Here you can see VB = 70.3V ('Bias Variables' window)
If it helps, I could send you a .doc file with the 'Print Screen' of PIExpert Specifications forms, Design forms, Input Stage forms ...
The size of this file is approx. 1700Kbytes
Thank you very much
Submitted by PI-Spock on 05/12/2009
I cannot view your attachment. Can you try to attach it again or just send me a PM?
Oops sorry. PM is private message. Just click my alias (Spock) and then select the "Contact tab" and type a private message and attach the file.
Submitted by cabedikes on 05/14/2009
I have tried a private message, but I haven't saw any tabs for your account. I send my the attachment to you again. I hope that it functions this time.
My problem is the following :
PIExpert calculates for my Design (with E-Shield transformer) Vbias about 70V. I think PIExpert is wrong because of PIExpert calculates, for a similar design, without E-Shield transformer, Vbias about 27V.
I'm interested in components with lower working voltage because of they are more cheap.
Is PIExpert wrong?
Thank you
Submitted by PI-Spock on 05/14/2009
Ok I can open this file. I can site several reasons why this is happening
1) for bias winding feedback - to provide some shielding the bias winding is wound as the first winding in the transformer.
2) Your problem arises because you have only 3 W design and you are using a core that is capable of delivering 13 W. As a result the primary winding only has 1 layer. This causes a large bias winding voltage. If you have peimary winding in 2 or 3 layers (which is what is normal for designs at this power level) you will see a lower bias wionidng voltage.
There are 2 solutions
1) Ideally, use a smaller core like EE13 or EF12.6
2) Duplicate the same design in PIXls and manually change the bias winding turns to a lower number (such that you see about 15 V on bias winding) This will disable the shielding effects of the bias winding but will work for you.
Submitted by cabedikes on 05/18/2009
I understand
Thank you very much!
