PI Design software for 3 phase design
I need to design a three phase power supply for a metering application. Can the PI Expert Design software do 3-phase SMPS design?
I was looking at the DER-58 but I need more that 3W and more output voltages. I was also looking at DER-105 but input is only from 207VAC - 400VAC.
Any help is much appreciated. Thank you.
Hi Tucker,
Thanks for the reply. Initial requirements are as follows:
Input: 85VAC - 580VAC
Output: 15V @ 1.2A, 3.3V @ 500mA, 4V @ 500mA (peaking to 2A)
Note that the 4V will be averaging 500mA but it will peak at 2A when GSM modem is transmitting.
-Leonard
I've been reading a few posts in the forum regarding the StackFET design. So can you use this procedure?
1. Use the PI Expert software to generate your preliminary design (85VAC - 300VAC as input).
2. Put another high-voltage MOSFET in series with the PI chip
3. Change other components to higher voltage rating (700V-800V if input is three phase)
4. Use the input stage (left of C9) on the DI124?
I'm sure it's more complicated than this. But for someone who is not a power electronics expert, where do we start?
I am in a similar situation and was also considering the process suggested by Ijarillas. In addition however, I noticed that PIXIs Designer doesn't limit the input voltages, so that could be used for the transformer design.
Any further suggestions?
I am also designing a 3-phase power supply and am facing the same issues that you are. I am using LNK304P as a Buck Converter. I am stacking up the capacitors for a higher voltage rating and also am going to try putting in the extra FET with the same biasing that they show in DI-124. The only difference is I will tie the FET drain to the positive rail because there is no transformer. I don't see any reason why it wouldn't work.
The best approach is to design the transformer using a PIXLS spreadsheet, and ignore the VDRAIN warnings.
Then add the required series MOSFET based on the PIXLS RMS Drain curent calculations.
Pls see my reply about 4 posts up.
What are your input and output requirements?
PI Expert does not have capability to design with "StackFET".
