Low Cost non-isolated Power Supply - to replace simple RC supply
I'm looking at the possibility of using an LNK306 as a cheap non-isolated 5V supply. The problem with my existing RC supply is that it only goes to 20mA and I now need 50mA - 200mA source. One of my design requirements is that the PSU must withstand 418VAC for 48hours, otherwise it is 85VAC - 265VAC.
Looking at a reference design like that shown in Fig 5 of the datasheet, can the LNK withstand 418V AC ! If not is there another option. ! Appreciate comments.
Hello MAC,
treez was kind to respond to your post and he is right, you can use LNK306 for your application with 418Vac input . Just make sure you use components rated for this voltage level, you have the proper spacing between high voltage traces (do you have to comply with regulatory requirements?), and your chip does not go too hot. It is possible to get some extra heat working at 600Vdc input, if necessary use a PCB area as a heatsink or a small heatsink wing soldered directly to the four source (S) pins.
Cheers,
PI_Crusher
Hello MAC,
You can check this design:
http://www.powerint.com/sites/default/files/PDFFiles/der47.pdf or go to this page: http://www.powerint.com/en/design-support/reference-designs/design-examples and browse any buck with LNK30x. You can not replicate one schematic with no changes at all, you have to use one as a starting point and make necessary changes for your input/output parameters.
Cheers,
PI_Crusher
