load regulation using TL431
hai all
in my power supply load regulation problem occurs.for no load output voltage is 9.5V.For 5A ,Load output voltage drops to 8.5v .the feedback used is TL431.plz suggest me the circuit to compensate this load regulation.
tried with following configuration 1)0.1uF disc capacitor in bias 2)0.1uF is replaced with 10uF 3)external 12DC Constant power supply given to bias winding no changes found in load regulation(with load).from this i conculde no problem with bias voltage. i am using top261EN with 132khz (source & frequency pin short), i measured frequency in digital oscilloscope but i found frequency range is 55khz. i used TL431 loop configuration as per design example.plz suggest me loop compensation configuration which provide better load regulation
Would you please post your schematic or send it via a private message. This issue is definitely avoidable and the schematic will help us figure out what the problem is.
Cheers
PI-Chekov
