LNK306 for high output voltage (310V/75W) buck converter
I am trying to generate a 310V output from the DC bus (around 380V) of a power factor corrected supply. I can't simply lower the DC bus voltage as the bus voltage needs to be above the maximum AC input voltage in order for the boost PFC circuit to work (unless I go for some complicated buck/boost arrangement) and there are some other parts of the system which need 380V.
So I am thinking to use a LNK306 to generate the 310VDC from the 380VDC bus. I need around 75W at 310V (around 240mA), so this is within the indicated limits (360mA) for the LNK306. However, I suppose those limits assume a low output voltage (say below 30V), where the switch will only be conducting for <10% of the time? Can I use the the LNK306 at high duty cycles (say 80%)? The FET conducted losses with 240mA and 80% duty cycle will be around 500mW for the LNK306 - what other losses to I need to consider when calculating the total power losses for the LNK306?
If the LNK306 can't handle this much power, can anyone suggest another suitable device, or perhaps a method of driving an external FET to increase the power handling capacity?
