flyback design problem...
ı made my circuit but ı couldn't see any voltage at primary and secondary winding of the transformer. application note:32 figure:4 is my circuit design(Primary/Enhanced Feedback Circuit)...
ı am giving the properties of my circuit below.
output power is 40 W..
output voltage is 1000V..
transformer EI33...
fS= 66 khz
ı used TOP244Y.
VACmın= 195 V
VACmax= 265 V
fline= 50 Hertz
Vbias=28 Volt
Primary;
1n4007 diode bridge
Cın=47uF 400V
P6KE180 (180 volt zener diode) + BYV26C diode
2.2 Mohm resistor for L pin
(for 66 khz C and F pin connected)
There are 6.8ohm resistor (1/4 watt) and 47 uF 50 V capacitor between F and S pin.
There is 12kohm resistor between X and S pin
Bias;
BAV21 diode + 100nf 50V capacitor
15 ohm resistor
1n5251 zener to C pin (22 volt)
100 nf 50V capacitor
Secondary;
High voltage diode( about 8KV and 0.6 A) ultrafast + 47nF 2000V capacitor
ı wait your help...
thanks...
Vor= 120 V
KI = 1
KP = 0.64
VDB= 0.7
VD = 0.5
http://www.powerint.com/sites/default/files/TOPGX Flyback Design2_0.xls
Could you please also provide your transformer information and other parameters in PIXIs Designer, such as VOR, KI, KP, etc.?
