desktop computer power supply
Posted by: bren on
Hello! I am planning to design a SMPS for the CPU of the desktop computers with total power of around 350VAS, 500VA and 600VA. What TOPswitch device should i use? Do you have reference designs for this?
Submitted by PI-Janeway on 01/09/2009
Hi There, Top Switches are optimal for using in Flyback designs and the ratings are below 300W. It still could be possible designing for higher power ratings but because of component limitations it needs special considerations and is not recommended. For your higher power designs a boost topology would be more convenient. Top Switch cannot be a good candidate for your high power designs. PI-Janeway
Submitted by PI-Bones on 01/09/2009
Chick Webb
Online Marketing Manager
Power Integrations, Inc.
Submitted by PI-Chekov on 01/09/2009
Typical configuration is PFC Boost front end then single ended or two switch forward (dependent on efficiency rating) for HV DC to LV DC stage (12 V and 5 V outputs, with mag amp from 5 V to 3.3 V).
As PI-Janeway mentioned our current products are not suitable.
Cheers
PI-Chekov
