Top switch HX, GX and tinyswitchIII
Posted by: bren on
Good day! I am a beginner in smps designing, i would like to ask, are the TopswitchHx, GX and tinyswitchIII all short circuit protected (i mean, the spms will not be damaged when i short circuit continously the + and - terminal of the smps)? if yes, then, what are the bias that i should add to its basic circuit to assure that it will not be damaged? Bren
Submitted by prasun on 10/08/2008
Don't worry friend...yes it is short circuit protected. no need to add anything. it is protected due the feature of auto-restart mode. when the feedback current exceeds certain level, it sets itself in auto-restart and once you remove the short circuit, it starts working fine. pls do check the reference notes if desired.
Submitted by bren on 10/09/2008
Thanks. I will try to short circuit it permanently. I will check what will happen.
Submitted by prasun on 10/09/2008
Don't worry...even if u keep it short for long time, once u will remove the fault, then also it would start...ITS PI product i believe.
