TNY266 problems
No there is no danger to designing for low powers...
From the PI Expert design files I dont see any problems. I may be able to spot something after looking at your schematic and layout...
maybe you have big loop areas, maybe you have too little heatsinking maybe you connected some parts of the circuit backwards (namely the clamp) I cant tell without looking at your schematic and layout
(PSU) is one of the few items in an electrical device that will affect the performance and reliability of 644-141 your entire system. It's often the most undervalued, under-appreciated component within any device, yet one of the first components to cause failure. 646-056 This article focuses on the factors to look for when purchasing a PSU for a personal computer, but it may be applied to any application needing a regulated PSU. 646-102 When following this guide, take into account your own application, and appropriately weigh each factor.
646-222
Can you attach your design schematic and your layout file? The PI Expert design looks fine and its ok to substitute a UF4007 in place of the FR106 diode for DB.
Also please measure how much leakage you have in your circuit and let me know.
